Did you guys know that the smaller of the two breather hoses is the crank case breather? As it's designed your pumping oil into your air intake. We know this as we have tested the blow buy pressure off this line. Problem or not for you, just thought you'd like to know. If your intake is slightly oily then your changing your air/ fuel mixture and will foul out your TPS, MAP sensors too. You'll see Honda designed this crank case breather hose to attach to the bottom of the air box allowing any blow by to drain out and with the large volume in the stock box (unless your rings are wasted) the exhaust gases will not effect the clean air coming in. We did some testing with a similar setup, the bike ran fine, but we could see slight traces of oil where we didn't want it.
For the record, Im glad to see others offering more product for the Fury, in no way do I see this as bad competition against our
Honda Fury air intake adapter. We see this as more products for the Fury which would give all more options and we hope would get more Honda Fury owners out there.
There's no doubt the quality of this product as Troy at Accutronix make some nice stuff and it's good to see their customer helping.
Chris
Low and Mean
