There has been alot of interest in adding ABS to non-ABS Furys, today I was looking thru the new parts update and pulled some prices for those wishing to add ABS. This is NOT a complete list of all the parts needed, just some I could think of off hand. Rounded off.
Front wheel 799
Rear wheel 826
Pulser rings 111 (2 req)
Sensor 135 (2 req)
Speedometer 628
Master cyl 143
Front cal and bracket 381
Rear cal and bracket 270
Sub harness 115
Modulator 1190
$4844.00, prices were MSRP, not inc hoses, brackets, mount and box for modulator, etc. The wheels may just need to be drilled and tapped, and if you don't want the ABS fault light, you don't need a new speedometer. Also may need a new main harness, I didn't check the p/n of them.
Front wheel 799
Rear wheel 826
Sensor 135 (2 req)
Speedometer 628
Master cyl 143
Sub harness 115
Modulator 1190
