1 - 20 of 37 Posts
Alright guys Im putting my first full summer with my fury in the books. I'm looking for YOUR best upgrades with the fury. I already have hacker ripper pipes, mustang front and passenger seat, spike intake, underflow, LED headlight, mirrors and fork speakers. Im repainting the frame this winter
Tigger scoop from SLK. Bad ass.
I can make you some cool custom stuff.
Vray is good. I have his highway plates for pegs.
· Administrator
Whatever you "have" to change, that's the way to go.
While a big investment, the Sumo-X fat rear tire kit adds a lot to the looks, though road cracks become harsher. An air suspension is pretty awesome, @Kbuskill has a lot of great advice, and there are threads on rolling your own. Mine bucks the trend by having lowered and swept back bars, if you want six-pack abs there's your workout. A side-mounted speedo is also a good look, but a bit inconvenient--everything has tradeoffs when starting with an awesomely designed bike like the Fury.
What is the feedback on these?
I don't make a habit of grabbing or squeezing anything like a knife blade. Bad things usually happen and the juice that's supposed to stay on the inside often ends up on the outside. :ROFLMAO: :ROFLMAO:
· Super Moderator
Being serious for half a second. The edges that you grab have hard corners and don't look very comfortable. Then what happens if your fingers get caught between the levers a the bars in an accident or if the bike falls on you and part of you gets stabbed by the pointy end? Probably a good idea to keep looking. Or you could be really radical and leave the stock levers on.
2011 Fury
I still have my stock levers and don’t “love” them, was thinking of swapping but haven’t found anything I like so I’m gonna put a leather wrap on them and see if that solves my craving to customize 😈😂 but I’m with @macxpert in this risk -vs- reward and if your overall “look/theme” isn’t in line with blades…. 🥱….
· Super Moderator
I just had my stock levers chromed as the aftermarket levers I tried didn't fit quite right, plus I was happy enough with them.
@SNAKE BIT
Having used the type of levers @FURY-S1 listed for the last 2+ years I would say they're not bad after moding them.
Out of the box they are wobbly. Press out the brass bushing from the OE levers, drill out the bolt hole of the new ones press the bushings in made a big difference.
@macxpert observation is mostly correct, the finger notches are uncomfortable without gloves on. Have not done it yet but planning on champfering the finger notches a bit.
The tip is not as pointed as the picture make it look but does have a sharp edge as a result of manufacturing. Couple of minutes with a file and problem gone.
As for getting fingers caught between grip and lever is no different then if they were OE. The edge of the blade is blunt.
My only real complaint with the levers would be with the finish. Typical cheap Chinese anodizing where the black will turn a bronze color when exposed to UV. Nothing a coat of paint won't fix.
Bicycle Bicycle tire Automotive tire Bicycle handlebar Bicycle part
2012 FURY
@SNAKE BIT
The ones from Amazon would be ok probably, but I want CHROME. I have spike nuts, grips, axel covers, etc all chrome spikes. Still looking I guess. The spike or knife edge would naturally be on the front side, not the grip. Thanks.
Shoulda guessed that you'd chrome em ;)
1 - 20 of 37 Posts
