In a word: gravity. And you already have some in your garage. Try raising the front of your Fury a foot or two off the ground. With the rear master cylinder above the slave (rear caliper) and also the highest point in the brake line you may be able to simply open the bleed screw on the salve and wait (no pedal pumping required). With a clear tube on the bleeder you should eventually see fluid with bubbles and then no bubbles at which point you close the bleeder screw. Be sure not to let the master reservoir run out of fluid while you are waiting. This works on automotive disk brakes which work the same way but I haven't tried it on a motorcycle. The wait can be a minute or two.
As mentioned in previous posts a vacuum bleeder would also work and in fact is very helpful in neighborhoods with low gravity
