1 - 2 of 2 Posts
I finally got the blade signals to work like I wanted them to. I wanted both lights to work as running and turn signal. If anyone is interested this is how to do it. If you have the ECLIPZE MODULE take the red wire from the input side. This is the side with 3 wires. Wire the red wire to the constant on wire of the signal. That wire will be blue or orange with the white stripe. Do this on both signals. Then connect the two together. Now you have the 2 red wires and the blue and orange with white stripe wire all together. Then wire the rest of the wire on the input side orange to orange, orange to blue, green to black. Try not to get them mixed up. Now on the output side. This is the side with a red and black wire. Take the 2 red wires on the Blades and connect them to the red and the 2 black wires to the black and YAHOO.
If you have any Q's just write and I'll try to help. GOOD LUCK. SCOTT
Thanks s.oliver, I think there are mulitiple ways' to wire these lights and have them work as you would like. good choice on lights;)
1 - 2 of 2 Posts
