1 - 12 of 12 Posts
I'm in the process of cutting mine off and putting on the Zombie shifter pegs.
They are made for a Harley so cutting the old ones off and drilling is in order to make them work.
I looked around on the web and could not find any made specifically for the Fury.
I had mine on order and saw 460brevill pic's of what he did..:)
That will be my weekend project..:)
Brevill,
How did you do the brake? They look great. I took my rear pegs off last night and trying to figure out the best way to do it.
You have to cut the stock one off, i took mine off the bike, cut the pedal part off, ground it nice and flat, drilled a hole dead center, sprayed some clear enamel on it so it would not rust and bolted on the new. I got mine at the local HD store, they have a good selection,
I cut mine off with a variable speed sawzall and a metal blade without taking them off the bike. Patience is in order if you don't take them off.
I taped up the chrome so no scratches.
I did spray WD-40 on the rubber shifter and removed it prior to cutting it off.
Filed them down smooth same a Clueless and applied clear coat on the bare metal as not to rust.
I must admit, I love the shifter now. It's a lot easier over the stock round rubber.
1 - 12 of 12 Posts
