1 - 17 of 17 Posts
Hello -
I purchased these LEDs for my bike. it comes with a blue wire but I need to connect it to the Brake so it will also light up. Can anyone point me to where I can find this conjunction box or where to connect this to? thanks
Sent from my iPhone using Tapatalk
Hello -
Can you post more info of the light.
These LED strips connect to the battery. black for negative, red for positive and Theres a blue wire for brake.
I would not connect them directly to the battery. Wire them up to the rear light harness. Given the wire color you gave, if I remember correctly, I think it would be
Light > bike
Black - green
Red - brown
Blue - green/yellow
There is a also manual you can d/l located at the top of the tech fourm I would recommend as a quick reference. May be a little hard to read on a phone but nice to have for that time when you just got to know now. ?
Discussion Starter · #6 ·
Light > bike
Black - green
Red - brown
Blue - green/yellow
Thanks for this info. I am still totally confused. I’m more visual as I have never accessed the rear light harness.
Fairly straightforward, remove seat and fender gets you access to the oe harness. Brake has 3 pin plug. Hard to tell from the picture but you may have problems with the control box mounting as there is not much room to work with. How do you plan on mounting the lights to the bike? What does the led section look like.
Discussion Starter · #8 ·
okay I took it off the fender and the seats. I see 2 pin plugs in back of the fuze box on the right side.
I have light strips under my gas tank, under my air intake. under the back and above my back tires.
After work I will come back and give you a better response. I put LED's on the back of mine, replaced entire stock set up
Ok, so it is a brake light is all it is correct? Black is the ground then, will connect to the green wire on the bike. Red would probably be for the running lights, which would connect to the brown wire on the bike, and blue is the signal for the brake light which would connect to the green & yellow wire on the bike. It should spell out in the instructions provided which each one is for correct? And you are running no turn signals? Or doing something else for them? What about the plate?
I would love to hook this up but I can’t find any information regarding this system
Did you not get it figured out?
2011 Fury
Hey guys; I’m getting ready to replace the stock brake light (brake light only) since the stock light looks like it’s LED so do I need any resistors?
1 - 17 of 17 Posts
