21 - 22 of 22 Posts
Take your bars off, cut the other bolt off. Center punch both studs and drill them out with a 5/16 drill. Thread the hole with a 3/8 tap, then you can run a stainless steel Allen cap screw up from the bottom.
I'd be more keen on doing it this way as well.
If I went the stud route I'd be using Loctite 620 (green)
I had 1 break off on me also and drilled and tapped it. Should have just done both sides at the same time, because now the other side has broke
21 - 22 of 22 Posts
