1 - 4 of 4 Posts
I have the cc solo seat with the t mod. Looks great, but you have to add spacers under the front mounting tabs of the rear fender. Otherwise you will see a bowing effect in the sides of fender with out.
Good Idea I did not think of that!
I took a pair of valve stems and cut the knot off of the end and it was the perfect height and even has a little hole all the way through if you wanted to run a small screw through it to secure it from moving or falling out. Put it where the old push tabs held it on. Raise the fender up a little and slide them underneath.
1 - 4 of 4 Posts
