Was thinking about buying these, they were made for fury. 10 inch rise. I heard you can re use stock cables if re routed. Can anyone help verify this? Thanks
Looking PRETTY!Just fitted those exact bars this weekend! You can reuse the throttle cables (both of them), the brake line and the wiring, but you'll need a longer clutch cable. All the cables are easily rerouted, but you will need to disconnect the brake line from the master cylinder when you do that one - just means you have to bleed the brakes. Don't forget to buy risers. It was a straight forward job, the whole thing start to finish took about two days in the garage. Let me know if you have any specific questions.
View attachment 239635 View attachment 239636
Pretty is the word I suppose!Looking PRETTY!
Can you share the risers you bought and where you bought the clutch cable? Looks freaking sweet!Just fitted those exact bars this weekend! You can reuse the throttle cables (both of them), the brake line and the wiring, but you'll need a longer clutch cable. All the cables are easily rerouted, but you will need to disconnect the brake line from the master cylinder when you do that one - just means you have to bleed the brakes. Don't forget to buy risers. It was a straight forward job, the whole thing start to finish took about two days in the garage. Let me know if you have any specific questions.
So was that gloss black for everything? What did you end up dropping for everything! Like $800?View attachment 239639
Thanks - here you go. I bought the complete cable kit from Mean Cycles to fit, but in the end I only needed the Clutch Cable. They probably do that on it's own.
Just short of $900, but I bought the complete cable set for $400 and you don't need them, just the clutch cable.Nic
Gotcha. You know how much longer the clutch cable ended up being?Nic
Maybe 3 inches, max.Gotcha. You know how much longer the clutch cable ended up being?
Don't like my choice of words?Pretty is the word I suppose!
Sweet. Sucks they don't give you the risers and everything with the bars. I'll be getting all these and def hit you up for any quick pointers if needed.Maybe 3 inches, max.
Not at all! I agree - pretty is a good description. I've always said it's a very feminine, curvy looking bike. You're not the first person to describe it as pretty!Don't like my choice of words?
No dramas - anytime!Sweet. Sucks they don't give you the risers and everything with the bars. I'll be getting all these and def hit you up for any quick pointers if needed.
I think you'll be safe with 2"So they have stock plus 2 inches or 4 inches. Safe with 2? Or go with the 4?
yes andWas thinking about buying these, they were made for fury. 10 inch rise. I heard you can re use stock cables if re routed. Can anyone help verify this? Thanks View attachment 239629
Have you got any wider shots of your bike?yes and View attachment 239642 yes
