21 - 26 of 26 Posts
Was thinking about buying these, they were made for fury. 10 inch rise. I heard you can re use stock cables if re routed. Can anyone help verify this? Thanks View attachment 239629
Just fitted those exact bars this weekend! You can reuse the throttle cables (both of them), the brake line and the wiring, but you'll need a longer clutch cable. All the cables are easily rerouted, but you will need to disconnect the brake line from the master cylinder when you do that one - just means you have to bleed the brakes. Don't forget to buy risers. It was a straight forward job, the whole thing start to finish took about two days in the garage. Let me know if you have any specific questions.
View attachment 239635 View attachment 239636
Are those bars wider than the OEM?
21 - 26 of 26 Posts
