1 - 4 of 4 Posts
Hey:
While I run the risk of coming across as a bit of a dunce, I'm looking for some feed back with respect to changing my headlight bulb. I've got my new Cool Blue 9003/H4 bulb and am raring to go. Any suggestions that will save me a little time and a bunch of grief would be appreciated.
I've noticed several screw heads on the sides and bottom of the headlight casing. Do they all come out or are there specific ones I have to pay attention to?
I know, I know, simple stuff, but what the heck. Thanks a million.
dougie b :)
There is a screw on the bottom center that comes out first, the top is held in with a tab and rubber grommet, pull out the bottom while wiggling on the top. Then there are 2 screws on the 5 and 7 o'clock position that come out and the headlight assy will come out. The plug onto the bulb will probably be a pain to pull off, I usually pry gently to pop it off. pull off the large rubber boot, there is a wire keeper that holds the bulb in, push in and rotate it a little then it will come back out of the way. Don't touch the glass part of the bulb, I usually put dielectric grease on the bulb spades before I plug them back on so next time it won't be so hard to pull off.. (aftermarket bulbs usually do not last as long as OEM)
Update on mod
Hey:
dougie b :)
So how did the modification go??
I would like to use the white light as well (matches snort scoop)
What is the actual part number you used, and was there anything else that was needed??
thank you
tony
1 - 4 of 4 Posts
