1 - 13 of 13 Posts
Here's a quick write-up of my DIY LED taillight setup.
I picked up the 11" rear taillight rig with amber turn signals and smoked housing from Chromeglow.com, plus the dual-element circut - $71:
LED Flexible Arrays Light Bar with Turn Signals - Chrome Glow
I then picked up some 1/8"x1-1/4" flat steel stock (4' piece) and a 24" piece of 1/4" square stock for about $15 from Lowes.
I pulled off the fender, and used cardboard to trace the shape of the bottom of the fender. I used a propane torch and hammer/bench vise anvil to form the 1/4" steel bar to match the curve. Took some time, but it's a learning experience.
I then took the flat steel, and cut a notch to allow me to heat and bend the it to close the notch and match the angle of the taillight substructure. I drilled 2 1/4" holes in each flat piece to match the spacing of the stock substructure mounting points, and threaded them with a 1/4"-20 tap.
I pulled off the taillight substructure and mounted the 2 new side bars with 1/4"-20 stainless steel panhead screws, and put the fender back on with the new structure extending past the end of the fender. I traced where the fender ended on the side bars with a marker, removed the fender, and cut the new taillight supports on the mark. I tack-welded the 1/4" square bar to the mounts, and test fit the fender.
I'll admit it took a couple adjustments, but it finally set just right, right on line with the fender height-wise and a little bit recessed. I finished off the welds, cleaned it all up with a wire wheel on the bench grinder, hit it with primer and gloss black paint, and mounted it on the bike.
Then i cut off the stock harness *way* up near the fender flap, and spliced in the new dual-element circuit for the brake light and soldered all the wires together. Since the unit has amber turn signals I didn't need any control boxes.
I replaced the turn signal relay with an LED relay from Cycle Gear, plug-and-play, and zip-tied it in place.
Finished look, no more lollipops!:
Looking good, glad you finished it!!!
there outa be 30 or so (MFR was here)'s out there :D
nice job--i'm inspired--I may get the side mount plate kit now...i like our fenders--and want to see more tire exposed, too.
I got mfr's tailights and the only thing left would be to move the license plate and my diode bolts to the side-so, I don't need but a few hours in the garage to "hammer" out my plan.
Good job bro, looks good... gotta love those Radiantz lights. Excellent add-on for anybody!
Fantastic look. Was thinking about putting my plate on the swingarm.....but decided to put a bag there instead. Another future purchase.
Awesome work man!!! Looks really good..
Looks good man, wish our law would allow those here!
In The Netherlands there must be 18cm (7,08inch) between the turn signals.
1 - 13 of 13 Posts
