No???
No???I noticed today when i roll my Fury backwards im getting a clicking that sounds like its coming from the drive shaft. It almost sounds like a roller coaster being dragged up that first hill. Has anyone else had any issues like this?
I did 300+ miles today. I didnt notice if its was doing it before i left but its sure doin it now.You may want to put a few miles on it if it has been sitting for a while. When I picked up my bike on Saturday from the shop, I couldn’t get it into Neutral, then after about 50 miles, everything is back to normal.
Was probably the flange drive, or do to the floating final the Fury uses, cause there is no way they took the rear assy apart and got it back together in the 2 hrs between your posts. Probably removed the wheel, spun the drive and the sound was gone, relubed retorqued properly and you are good to go.Ok well not too sure what the problem was but the dealership took the rear assembly apart and put it back together and the problem is fixed. I am being led to believe something wasnt as tight as it should have been. The guy said "we took it apart. Nothins wrong in there. We put everything back together and tightened everything up. It shouldnt happen again" 4 guys looked it over afterward and everything was good to go.
Thanks for all the help, info, and tests you guys did for me.
Yea it was only a couple of hours which is y i think it was sumthing that was loose.Was probably the flange drive, or do to the floating final the Fury uses, cause there is no way they took the rear assy apart and got it back together in the 2 hrs between your posts. Probably removed the wheel, spun the drive and the sound was gone, relubed retorqued properly and you are good to go.
Not good, Richard. Sorry to hear that. Hope you get it back soon and all is well. Very interested to find out what the problem is.Crazy thing happened this afternoon. I was on a ride and about 40 miles into it I started hearing clanking sound coming from the rear end. Sounded like a bolt getting kicked around and rattling. I took it into the shop and the service manager road and heard the same thing. He didn’t know what it was either. Almost sounded as though it was coming from the hub/final drive area. Guess I’ll be without my bike for a few days.![]()
