1 - 14 of 14 Posts
oops, looks like it's hydraulic clutch only... Wonder if it possible to install slave sylinder on the clutch...
I have converted one other bike, but the Fury would take some doing because there is no kit that I am aware of. I don't know how to make one.
Discussion Starter · #6 ·
Hey let me know if you go for it, I'd be interested in buying your current set up
It will be 3 holes in the middle of the bars (2 small mounting holes and larger one for the wiring) Unless you want to cover the cost of Motoscope Mini speedometer, mounting bracket and indicator lights. :wink:
Oh, I already ordered clutch slave cylinder, it fits perfectly on Fury in the same bracket as clutch cable! I guess I will be the first on with hydraulic clutch on Fury! :co-ol:
It will be 3 holes in the middle of the bars (2 small mounting holes and larger one for the wiring) Unless you want to cover the cost of Motoscope Mini speedometer, mounting bracket and indicator lights. 😉
I know this post is several years old, but did you buy the bars and do the conversation?
I do miss Evo being around, he posted some really good shit. Unfortunately he hasn't posted in like 7 years. Maybe some forum member keeps in contact with him, maybe via the facepage or something.
Administrator
Exile cycles has all the parts and still doing this stuff.
Thanks for the info. Time to save for winter projects now. Unless I can get Corn Pop to send me more Checks!!!
1 - 14 of 14 Posts
