Does it change the sound or hurt performance? I like the sound with them in, but I would not mind rattling some windows either as long as the sound and performance are not changed.i took the baffels out the day they arrived.awsommmmmmmmmmmmmmmmmmmm.sound.dont forget to reset you computer.disconnect battery and turn key on.let i drain for 30 minuts.restart engine and do not goose throttle for 15 minuts.ready to go.
Good advice!!!!!.dont forget to reset you computer.disconnect battery and turn key on.let i drain for 30 minuts.restart engine and do not goose throttle for 15 minuts.ready to go.
Disconnecting the battery does reset the ECU, but it just clears any faults the dealer can also reset it with an HDS, but I agree completely with the rest,this bike doesn't have an adaptive or learning ecm, it uses pgm-fi, which means that the fuel and spark delivery is pre-programed, or "mapped" for all the various engine temp, coolant temp, air temp, barometric pressures, etc... that the bike will see, and disconnecting the battery doesn't reset anything.![]()
Hmm, that's interesting, haven't gotten the manual yet but i assumed it would be similar to the vfr, which requires you to jump two connectors in a service plug to reset the fault codes. i thought that was so that if the bike lost power, it could still be diagnosed.Disconnecting the battery does reset the ECU, but it just clears any faults the dealer can also reset it with an HDS, but I agree completely with the rest,
