1 - 20 of 40 Posts
so, the Cobra Pipes aren't any louder than the stock pipes?
They are louder, they are about twice as loud (generally 3db louder), if not more than that (probably even 6db louder). Most of the aftermarket pipes though, because of the Honda engine, are relatively quieter than on a Harley at idle, but quickly gain the much needed volume from them when gearing up the speed and at traveling levels.
Does anybody have a picture of the baffels ? Just wondering if you could modify them to be a little louder without going to the extream ??
I'd like to see what they look like too. Also, I forgot who it was, but someone on here took the baffles out and cut about half of them off and put them back in for an even different sound level.
did you have to remove the pipes from the bike
shouldnt have to, might make it easier though but i would try it with them on first.
Just for that you made me get more than my 666 posts
You don’t have to remove the pipes. It’s actually easier with them on. That way you don’t have to try and hold the pipes also. I road for a month or two with them in, then decided to pull them. Now the bike sounds much better IMHO.
..So maybe just cut in half and reinstall..?? I would like a little more db just don't want to kill my headset for music & communications....wait..it is my wife that will want to talk sooo maybe leave them out..??..:eek:
cut the baffle after the first restrictor.then put a 3/4 inch hole in the restrictor.you will be amazed at the sound.also,if mr. flathead trys to put his nightstick in it you are still leagal.
1 - 20 of 40 Posts
