1 - 15 of 15 Posts
Sorry about the confusing Kuryakyn thread I posted last week. I stated that their website lists only 2 items for the Fury-Engine Case Cover and Master Cylinder Cover. With that statement in mind, some of you have stated that you have installed Kuryakyn Deep Dish Turn Signal Bezels with Smoke Lenses on your Fury's(confusing to ME-how can this be done when they don't make them). Tech Support at Kuryakyn has clarified all of these facts and says that they will probably be releasing turn signal products for the Fury in the near future and that those of you who say that you already have them are probably using a bezel/lens for a different bike and altering it to make it work or you may have gotten lucky and it fits right out of the box. That is what I was wondering about-what product(part #)did you use and did you have to alter it to make it fit? I am interested in doing both front and rear.
Thanks Again
I used the LED Silver Bullets #1613 on the front and the back. The back mounted on my strut. I do not have the stock fender anymore. On the front you will need a bracket. I ordered mine from Paul at Stumpwerx (AKA Arizona Phats).
Arizona Phats
374 Lily RD
London, KY 40744
1.606.877.5625
1.606.521.0122
[email protected]
Same here, extra set of smoked front and rear. I did what Richard did, just mounted them different, I use halogen mini silver bullets with 49mm 2 pc clamps and wrapped a thin pc of metal behind the clamps
I see that now.
I didn't mount mine with a bracket like yours, I used a Kury 2 pc clamp. I wanted mine in the same place as the stock lights, wanted them even with the headlight
I thought about that and I may slide them down flush with the HL, not sure. Its sitting in the shop right now waiting on the wheel chromer
I like them in the same place as the stock lights, better than the harbor lights that were on it
I don't know if its of any interest to any of you who are swapping out you stock directional lenses but thought I would mention it as an option. When I first purchased my fury I installed a set of the mirrored chrome lenses that I had removed from a Shadow VTX that I had hanging around my garage and I got to tell you they looked real cool on the bike and a lot better than the stock ones and fit with no problem.The direction housing used for the fury are the same that Honda has been using through out the years on the VTX. I have since swapped these out for the bullets lights but I did cut down and grind these mirrored lenses ito fit the bullets only because they looked so cool. I only bring this up as another option to the smoke lenses because I think they look a lot better than the smoke lenses.They look like a piece of chrome until you turn the directional light on allowing the amber light to shine through but when they are off they appear to be a chrome or mirror type finish. You can often find them on ebay and you just might want to check them out as another option for you if your staying with the stock lights. Good Luck!
1 - 15 of 15 Posts
