Cutting the plastic fender
1336 Views 3 Replies 4 Participants Last post by  scotty g
Has anyone had experience cutting the front fender yet?
I'm wanting to shorten it and kind of curve it like the front of it.
I know it's plastic, just wondering what would be the best way. Too much heat from cutting and the melting begins..
Any feedback would be appreciated
T
1 - 4 of 4 Posts
Tony,
I haven't done it on the Fury but I have on other plastic fenders. :)
I took a small cutoff wheel and did the contour cut going slow and not getting too hot. I did not cut all the way through on the first or second pass...just made the indentation. Finally ... All the way through. Then I sanded the edge down smooth and then even smoother. Repainted and looked good. ;)
I was going to try with a zip saw but those things can get away from you!
Tony,
I think I would do it Painters way.
But, a belt sander with several different grits of sanding belts could produce a nice job too. The key either way is go slow to avoid heat.
T
I THOUGHT ABOUT LEAVING MINE OFF, I HAD IT OFF FOR PAINT AND IT LOOKED PERTY GOOD OFF!:cool:
1 - 4 of 4 Posts
