I haven't done it on the Fury but I have on other plastic fenders.
I took a small cutoff wheel and did the contour cut going slow and not getting too hot. I did not cut all the way through on the first or second pass...just made the indentation. Finally ... All the way through. Then I sanded the edge down smooth and then even smoother. Repainted and looked good.
I was going to try with a zip saw but those things can get away from you!
I think I would do it Painters way.
But, a belt sander with several different grits of sanding belts could produce a nice job too. The key either way is go slow to avoid heat.
