I have a California Model Fury. This past weekend I removed all the CA EVAP emissions stuff and the PAIR valves.
For the EVAP job, I used a 1/8" rubber vacuum cap (you can get at any auto-parts store) to cap the vacuum hose outlet on the throttle body. I disconnected the fuel tank breather hose from the EVAP canister and allowed it to hang under the bike. I removed everything else (the EVAP canister, canister hose, Purge Control Solenoid Valve, vacuum hose, air inlet hose) and put it all in a storage box.... in case California decides to start requiring SMOG checks for bikes.
For removing the PAIR valves, I used Biglry & Bone's Block Off Plates from FastCycleParts.com. When I removed the air suction hose from the air box, I used a 1/2" rubber vacuum cap to cap the outlet. I then put the PAIR valves, solenoid valve and hoses into the storage box with the EVAP stuff.... just in case.
This all went very easy on the Fury. You don't even have to remove the fuel tank. I would definitely recommend doing the PAIR valves if you are having any problems with backfiring / popping on deceleration. (The PAIR valves suck air into your exhaust and intentionally cause your bike to backfire).
P.S. - If you want to get Block Off Plates (or anything else) at FastCycleParts.com, you can use COUPON CODE: 11F928098A. It will save you $20 off an order of $100 or more.
