Other than price, can anyone tell me the difference between Raw Designs brake light and this one: HONDA FURY 10 11 LED INTEGRATED TAIL LIGHT BRAKE LIGHT - eBay (item 130479027586 end time Mar-25-11 13:15:36 PDT)
Bracket I was going to make a new one but thought I already spent money on a inferior product(lesson learned) I want to do it right and have as much visibility as possible this one just did not cut it for me! JMHO but I have not received my rawone yet so I can not really compare hopefully someome with the raw will chime in!I assumed it'd be lower quality....still......its more than half of the Raw. I'm seriously considering it, must be a way to inexpesivly improve the bracket.
From my how-to post, here's how the L&M Radiantz light works:I currently have the RAW, but I am in the process of installing the L&M rear fender with the Radiantz. I have been told the RAW is slightly thicker and longer so it wraps slightly more around the side of the fender, but I can't confirm this yet because I have not installed the Radiantz yet. The RAW is all red when on and when the turn signal is flashing half the brake light flashes in red so half your brake light flashes. It makes your trun signal very obvious while still staying red. I really liked this option, but I think the RAW may not fit as well on my new fender. The Radiantz is mostly red when on except for the ends on each side which flash in the normal turn signal color when your turn signal is on.
Here's my full demonstration of the Radiantz light that came with the Low & Mean Reaper Fender in conjunction with the Kisan Tech SM-3 Signal Minder I had already once installed on this bike. It remained connected to the same Fury harness wires and the proper behavior carried over, simply, to the Radiantz LED lights. Very, very please!!
It was mounted by Painter when he did my fender for me.Thanks for the vid, that helps alot. How did you mount it?
I dont think you can beat it price wise and they are nice and very bright. Make sure to buy the dual element circuit to run both the run and brake light. I purchased the larger one 14" one below for this fender but I'm going to get another smaller one for the fender design I'm working on now.Dave, I did see those. I think that is what I might end up doing but I need to find a way to mount it cleanly.......and I'm not very handy
Save your money the product is garbage and the customer service is even worse ,then the products if that's possible , Sportbikelites.com sells garbage and backs that up with more garbage , they are located in Cocoa Fl which is only a 30min. ride for me and I will never deal with them. really bad people which is matched by an inferior product. Raw design may have a few kinks but they do all they can to keep you happy and rolling .Other than price, can anyone tell me the difference between Raw Designs brake light and this one: HONDA FURY 10 11 LED INTEGRATED TAIL LIGHT BRAKE LIGHT - eBay (item 130479027586 end time Mar-25-11 13:15:36 PDT)
