Pic #1 …
The first thing you want to do is clean with an automotive wax and grease remover. Rub with a rag and dry immediately with a clean one. This removes wax or grease that you could sand into the fender by mistake.
Pic #2 …
Red filled a hole he wanted to remove with “kitty hair” reinforced filler. He beveled the edges to make a ‘plug’ and then put tape over the top and filled in from the bottom leaving a little on the underside of the fender. Since fiberglass resin contains oil, sand the "kitty hair' and clean this spot with acetone. This is the one step putty to fill in the remainder of the hole and scratches.
Pic #3 …
In two quarts of water put several drops of ‘Dawn’ detergent and mix. When you wet sand you will need the soap to keep the paper from ‘loading’. Here I am wet sanding with 300 grit automotive wet/dry sandpaper. Don’t use regular paper. The block is to sand flat.
Pic #4.…
Sanding almost done. See what is left?
Pic #5...
When dry, if you see shiny places, you need to sand them out. Don’t worry if you go through the paint--just get it flat.
Pic #2 …
Pic #3 …
Pic #4.…
Pic #5...
