So you want to do the RAW led but dont want or can't afford side mount. Here is my Solution. Cost was i think 20 bucks with alot of left over AL angle, you could do it for about 12 if you have the Angle already. The light i used was a hoglites 5 LED plate light which sticks on with 2 sided tape.
with just the RAW LED your here
if you take a piece of Angle (i used aluminum) cut it to the width of the RAW plate mount holes or to the width of the plate (Whatever is wider, mine was cut to 1/8" narrower than plate to keep it from showing from behind the plate but that was the widest mounting surface i needed) Then cut two notches in the top portion of the angle just inside of the RAW tabs and bend the middle up to allow a surface for mounting the light (to help with bending clamp bracket in a vice then slowly bend up with some pliers, you can also heat it to help too).
I left mine stepped out a little to give the angle of the light projection a better illumination on the plate
then start drilling the holes for mounting, if you mount as far in as i did you will have to bend the tabs where the bracket mates against the RAW led's bracket to angle the plate away from the tire just to make sure it doesnt scrape the tire.
this is it mounted. I will do finished pics soon, just didnt have time right now
