Drain plug issues
1 reading
5.2K views 17 replies 10 participants last post by  ozzman
#1 ·
Damn I was changing the oil, put new crush gasket on and started to get it tight then now I think it's stripped. I don't see any damage to the plug praying that's all that's wrong.
#3 ·
It has to be torqued to specification to avoid this. May have to retread it.
#17 ·
be careful not to use it in cold surroundings though. It wont give a proper reading if it is a click torque wrench. I use a dial after I had one snap off my triple tree pinch bolt in 50% weather. That was f@c%ed. My bike was sole transportation at the time too.
#5 ·
Well good news, I pulled the drain plug out and noticed the last thread was flat. So I pulled the front drain plug out and put that on in the rear bam no issues. Thankfully it's just the bolt. Sucks I can't ride to work tomorrow, looks like I will be calling around to find a new drain plug.
#10 ·
I bottomed my Fury out while loading it up in the U haul last summer after my fuel pump failed on the way to the Dragon. I've had a drip problem ever since. My little Honda Davidson in the basement with a pig mat catching the oil. I'm due for an oil change so I guess I'll take a better look at it then.
#18 ·
Think i learned all about alum parts putting a alum intake manifold on my 69 impala when i was 20yrs old.....threads are not forgiving at all.....
