Clueless, wasn't there something posted about the sharp edges on the cover install clips on the cover cutting or clipping some wires behind the cover causing a grounding, power, starting issue?
PS Posted by Captainfester, 07/06/2010
Ride side removable panel scraped and cut through a couple of the wires in the bundle near the shock load set knob. Now bike won't start! Gotta bring it to the shop.
Posted by RSS 07/06/2010
Guessing it was from taking off and putting back on the side panel. Mine started to cut into my wires a couple of months ago, put some electrical tape over it though before it caused any type of serious damage to it and has effectively protected them since then... What he also may have to do is cut that zip tie that is holding that wiring harness there, in order to give him some slack with the harness, so he can move it around when putting on the side panel, I also did this and now can move my harness over when I go in and mess with the shock settings and now I can slip it on within a couple of seconds because of this
Posted by Imwright 07/10/2010
Cut 1/2 way through a green wire with mine. Went to check and see if my Diode was the same as a CBR i was working on and noticed it started to cut. I have only had that cover off and on maby 5 times since i got the pipes. I undid the ziptie, the front t holder tie that is electrical taped on, and shaved the nub down a touch. wondering if there is anything else to help prevent this.
