Hi all Does anyone know where the flasher relay is mounted? Todde.,.
toddekarr · Registered Joined Jul 1, 2009 · 9 Posts Discussion Starter • #1 • Jun 29, 2010 Hi all Does anyone know where the flasher relay is mounted? Todde.,.
Dave Maher · Super Moderator Joined Jul 5, 2009 · 4,476 Posts #2 • Jun 29, 2010 To access the turn signal relay you have to remove the seat and rear fender. Two wire relay look for green wire and white & green. Good Luck!
toddekarr · Registered Joined Jul 1, 2009 · 9 Posts Discussion Starter • #3 • Jun 29, 2010 Thank you very much.,.,. Todde.,.
RedspawnSilver · Premium Member Joined Aug 25, 2009 · 6,195 Posts #4 • Jun 29, 2010 Interesting avatar...
TrueBlueFury · Registered Joined Jul 17, 2011 · 80 Posts #5 • Feb 5, 2012 For those like me that need pics to understand, here's where it is. I spent way too long looking before I finally pulled the fender off and found it. Attachments Slide1.jpg 55.9 KB Views: 1,236
