I have been searching and reading posts. If I do pipes I need the FC. Do I do the FC first? I already put in a K&N filter because it had the original. Eventually I want to do the spike.
thanks
thanks
Check the plugs first. If they read "rich" then of course no, it's good to go.I have been searching and reading posts. If I do pipes I need the FC. Do I do the FC first? I already put in a K&N filter because it had the original. Eventually I want to do the spike.
thanks
I see you have changed your numbers ... closer to what Cobra recommends for their setup.Actually u need the FC with intake changes. Just Pipes you could’ve avoided it, modify both pipes and intake - you need the FC. In all honesty I’m running a full cobra setup, pipes, intake and tuner and my tuner is now set at 1-2-2 and it’s rich. I’ve posted before about seeing other Furys and VTX line bikes running intakes and pipes without a FC and running fine. I’ve seen people doing this that does not mean it’s ok or not, idk I just know people do it.
Yes, after Daytona I noticed the black soot on the fender and took it down. With regular gas and those settings I ran her 135 miles on one tank and mind u I was doin 75-80 most of the time. And the fender is nearly clean, little fog from the exhaust and the rain mixing. Forgot to hit u up… my bad dawg!I see you have changed your numbers ... closer to what Cobra recommends for their setup.
