I'm going to see if I can figure out how to post a video today. I can tell you that I'm real happy with the sound....I'd have to call it deep and throaty. When I took the first ride yesterday, there was a little popping and mild backfiring, but nothing offensive. I'll try to post a video so you can check it out for yourself.LETS HERE THEM
I can tell you, I'm no mechanical genius and I got it all done in about three hours. I did find myself sitting there scratching my head a couple of times because of the lack of good instructions (Fuggin's and the Fury repair manual). When I was done I fired it up and all was good.Hey Sundance...they look great! Mine are due to get here Wednesday....can't wait.....any tips on the installation of them or the fuel controller? .
Much obliged for the feedback.....Doug at Fuggin told me over the phone when I ordered it that it didn't matter which wire plugged where....but I don't yet even know what to plug into (I don't have a shop manual)...gonna wing it.I can tell you, I'm no mechanical genius and I got it all done in about three hours. I did find myself sitting there scratching my head a couple of times because of the lack of good instructions (Fuggin's and the Fury repair manual). When I was done I fired it up and all was good.
There are no instructions for the exhaust themselves. The bracket comes with three mounting holes, one for each pipe and one that bolts to the frame. What you get is a piece of tape wrapped around one of the bolts marked "FRAME", and that's your instructions.
Instructions for the controller are not very detailed either. One you remove the air cleaner cover, the air cleaner and the air cleaner housing (had minor issues removing the housing because the instructions in the Fury repair manual forgot to mention that you needed to remove 4 screws towards the center, remember, I'm an instructions guy. I don't like to wing anything) you'll see the wiring that you need to tap into. Instructions don't tell you which of the two leads goes where and I really don't know if it matters. All I know is the bike fired right up and ran very well.
Anyway there are 2 basic leads coming off the controller and a ground wire. I chose to run the controller itself and the ground wire over to the left side of the bike and ground on the negative battery cable. Also I mounted the controller onto the side of the battery by placing it right under the battery strap. Very secure. I don't think that will cause any problems, but I'm open for feedback on that.
Good luck with yours!
I needed 12 & 14mm sockets with extension (one place I needed to slap a 2nd extension on) I also found combination wrenches to be helpful (open end on one end, rachet on the other) I guess that's what you call them. As I said, I'm no mechanic so that says something about how easy this job was.Much obliged for the feedback.....Doug at Fuggin told me over the phone when I ordered it that it didn't matter which wire plugged where....but I don't yet even know what to plug into (I don't have a shop manual)...gonna wing it.Have done some shadetree mechanicing on bikes over the years, but none with EFI. Did you put the controller in while you had the stock pipes off, before putting the reapers on? I know you have to be able to fire the bike up to let the controller do it's thing initially.....any issues with the nuts holding the pipes to the heads? I just have your usual metric sockets, wrenches....I know I've read somewhere on the list that one of the nuts is a bear to get to....did you use any special tool? I gotta go to the dealer tomorrow and get a couple of gaskets....do i need anything else?
Thanks for your help,
Bob
Hmmm,,,, I have my parts shipped directly to the shop so the wife doesn’t see them. Do you think that is a problem?Wife just called me.....pipes and controller have arrived....and lo and behold, the dealer came through and got the exhaust gaskets in........licking my lips here!!!! Like a kid in a candy store....
Again... whoever came up with the saying "ignorance is bliss"... is so right... lol...Hmmm,,,, I have my parts shipped directly to the shop so the wife doesn’t see them. Do you think that is a problem?
Funny thing happened last Saturday when she took me up to pick up my bike. The Service manager had it all shined up and ready to go when we got there. We walked in and the only thing she noticed was the Fuggin Air Intake! She said “what’s that thing for?”. She didn’t even notice the Sumo 250 tire kit!![]()
