61 - 65 of 65 Posts
Aftermarket indicators should be DOT compliant so they're visible from all angles under all conditions (like sunlight). I'm kind of preachy on this, however want motorcyclists to not get clipped by vehicles that can't see the glow from poorly implemented aftermarket LEDs.
When I first landed here members suggested draining the final drive oil every oil change, and it's great advice. Your finial drive is probably fine. Keeping the oil clean reduces seal wear and helps prevent future leaks. If you want the Harley guys to think it's a Harley just bring a small bottle of used engine oil with you and squirt a bit under the engine when you park it. :ROFLMAO:
One of my dad's favorite lines (who drove several Harleys over the years) was "if your Harley isn't leaking oil, then its out of oil" o_O
Discussion Starter · #64 ·
I specificlly wanted the stock signals back on my bike because of the fact you can see that edge of amber from the sides. I haven't installed the signal flash modular, nor have I purchased the LED bulbs. Thats low in my to do's.
I need install/creative advice guys. I wish there was a way to not drill hole through the fender.....
Wheel Tire Automotive parking light Vehicle Automotive lighting
Wood Bicycle part Eyewear Font Automotive exterior
· Administrator
Last poker run I went on the gal that invited me, who always showed up 15 minutes early, was 1/2 hour late. Finally found she'd broke a spark plug.
I've driven several Harley's I loved driving, in some ways I wish I owned one. However, something as simple as changing the oil is an example of why I don't own one.
Fury stuff: I have arms the backrest plugs & pins into, no holes.
61 - 65 of 65 Posts
