1 - 15 of 15 Posts
the seat is the most comfortable seat i've ever sat on althought i too like the solo for just ramming around .....i bought it mostly for long trips and the occasional passenger turn signals front and rear are emgo dual filament bullets
That actually looks decent. Can we get other angles?
Seat only or bags only just did not seem right to me, but seat with bags is much better looking IMHO.
That is exactly my thoughts :cool: To have one without the other makes it look like it's missing something... You sir, found a winning combination :D
Discussion Starter · #14 ·
when i get a chance i'll take a pic but bracket is a very simple z arrangement ....attachment is 2 bolts under fender on frame rail and any bag with solid back could be attached to bracket with 2 additional bolts inside bag....no holes in fender and as easy to take off as removing seat and raising fender slightly and removing bolts...i would have liked them a little lower but you are limited by swingarm/hub clearance and i wanted the bags as close to bike as possible....bracket material is 3/16 steel....4" wide and requires 2 right angle bends in each one or you could cut and weld...hope this helps
1 - 15 of 15 Posts
