1 - 7 of 7 Posts
2013/7K miles. Enough gas/battery charged. Bike won't shift into Neutral. Bike could start in 1st gear with clutch engaged - but doesn't crank. Could it be a tranny issue?
Not likely...
238086
Running the wrong oil seems to (in some cases) cause Honda clutch plates to stick together, but that doesn't exactly sound like your problem. The Fury can be started in gear with the:
  • Ignition in the Run position
  • Emergency Shutoff Switch in the Run position
  • Kickstand up
  • Clutch pulled in (disengaged)
Try finding neutral between 1st & 2nd by rocking the bike back & forth a bit, then try starting it.
1 - 7 of 7 Posts
