In the "problems encountered" thread, Furyrider_ledez09 stated he was able to slow his idle down. I PM'ed him how and here was his reply...
Furyrider_ledez09's Idle Mod
I did this tonight. It took maybe 30min and the idle with stock airbox and exhaust is noticably lower. Once again I could not get the video to embed, so here is the link.Well, its kinda a bitch and the bikes ecu will only let it go so low, but here it goes...
First you have to take off all air filter box stuff similar to installing an after market intake adapter. you will have to take off plastic head covers for more room and work ability. Next your will find the two throttle cables coming in to the throttle body and if you fallow this with your eyes you will see the throttle body cable blade cam (half moon shape) well that will swing back and forth as you pull the throttle. This rocker has a stop which is a set screw just under the throttle body's blade cam. now this is the tricky part, but if you can take a 7mm open or closed end wrench and bend it to have a 90 degree so you can get behind to the back side. Keep in mind that your working between two cylinders heads thats not exactly the as spacious as a chevy if you know what i mean...
I found the best thing is just to remove the all thread acting as a back stop. what i found is that the bikes ecm keeps the idle from going to low, but the factory doesn't set the screws all the same distance (due to high volume production) and sometimes the screw will actually keep the bike idled up slightly in my case. so the bike now idles just low enough to hear a slight stump in the idle which is the way i like it. the motor sounds way more relaxed at a light as appose to the high idle and getting way to hot. Ill try to submit some photos explaining.
