(laughing) Wow. These guys just don't seem very sympathetic. You have several choices, but throwing the bike away, while funny, would not be my first. 1) Buy a new tank from Honda. 2) Find someone very good at body work and matching paint. 3) Get a small bottle of that matching paint chip repair from Wal-Mart. Of course that would like crap.Throw the bike away and get another one....
For those considering adjusting your housing down...... DON'T! I would highly recommend swapping the mirrors, but don't adjust the housings to make the mirrors work. With very little modification, you can modify the mirrors so they will adjust far enough, but with the housing in it's original spot.I just had about the worst accident ever.
While adjusting the housing down to make the billet mirrors work, the brake line with the little extended piece jammed into my tank when I turned right leaving a very slight dimple but a very noticeable chip in the paint.
Arrrrggghhhh!
Any suggestions?
What is wrong with adjusting the housing? My mirrors and the adaptors are not like the ones above, they are a single unit.For those considering adjusting your housing down...... DON'T! I would highly recommend swapping the mirrors, but don't adjust the housings to make the mirrors work. With very little modification, you can modify the mirrors so they will adjust far enough, but with the housing in it's original spot.
From my previous post:
When I received mine, I was disappointed to see that the mirrors could not adjust far enough to function as a proper rear-view mirror. I see other people have adjusted their levers down to compensate, but I didn't want to change the position of the levers. Instead, I made a simple modification to the mirrors to allow them to adjust farther...and now they work great, and look great. Here is what I did:
-Unscrew the post that attaches the mirror to the bracket.
-Just above the ball-and-socket connection, drill a 5/16" hole in the back of the mirror. This will open up the top side of the socket and allow the mirror to adjust much farther than it did out of the box. (Use a dremel tool to clean up the hole if needed.)
-Screw the post back into the bracket and mount on the bike.
Nothing, Honda sets them for a generic rider, many move them to a more comfy fit, its too late to tell you to check and make sure they don't touch. !. Go to the dealer and get a tube of touch up paint. 2. Go here Motorcycle Paint :: Touch Up, Aerosol & Refinish Paint - ColorRite and get touch up paint, go here and get a graphic to cover it DCG Customs Motorcycle Decals and Biker shirts and Decals or 4 go here Custom Motorcycle Painting | Custom Painter and get a kick ass paint job. Depends on how much you want to spendWhat is wrong with adjusting the housing? My mirrors and the adaptors are not like the ones above, they are a single unit.
http://www.grcustoms.com/shop/produc...roducts_id=683
