The bike shop i took my fury to, the mechanic there told me not to buy the Fi2000 that its garbage, to spend the extra money and get the power commander.
Really? I thought with the aftermarket air filter, you would need to adjust the settings. That's curious. When I get my Cobra breather, I had planned on adjusting the settings. Of course, I'm assuming that Cobra will give me an idea of what to set it at......I hope!Congratulations on your new fuel processor. Now you can read the six thousand posts and different views on this subject and hopefully if your head is still attached by the time you get done you might find a happy medium setting for your bike. I'm running the fi2000 with cobra swepts with baffles in with spike air filter at the default settings 1-2-0. I have played with the settings and I found no difference in performance so I left them at recommended default setting. Check the search button for this subject and view the many reports.
SteveO, I thought so to and have played with these setting til the cows come home and have found no difference in performance.You may also find the same result with yours when your cobra intake comes in especially seeing as we both have the same set. It seems to run fine and I've learned over the years not to try and fix anything that aint broke. I'm sure once I get my new inspection sticker and should I decide to pull those baffles out we might be having a different conversation.Really? I thought with the aftermarket air filter, you would need to adjust the settings. That's curious. When I get my Cobra breather, I had planned on adjusting the settings. Of course, I'm assuming that Cobra will give me an idea of what to set it at......I hope!![]()
Do you even have your fuel processor hooked up, or is it just velcroed in there?SteveO, I thought so to and have played with these setting til the cows come home and have found no difference in performance.You may also find the same result with yours when your cobra intake comes in especially seeing as we both have the same set. It seems to run fine and I've learned over the years not to try and fix anything that aint broke. I'm sure once I get my new inspection sticker and should I decide to pull those baffles out we might be having a different conversation.
WoW!!! thanks for the substance!!!ok.i have the cobra swepts with 1/3 baffles and [email protected] air.i run the fi2000 and set it 5 or 6 times.i finaly dun the unthinkable and dun it according to the stupid instructions.low and behold it worked.i ended up with 1-2-2.it runs great in and around town.if takeing atrip i drop to 1-2-0-default for mileage.if i want to mess with heads i go 1-2-6 for top end torque.as you get use to it you will see the diff.good luck and ride safe.
I don’t know why, but my bike runs the best at 7-8-6. Honda did the install and tuning. I emailed Cobra about my settings and my concern for fouling plugs or washing out the pistons. They sent me an email back essentially saying if the bike was running good, pulling thru the gears etc, then it was fine and not to worry about the numbers. Go strictly off how the bike runs. I posted their email on here somewhere.I think Richard is up in the 8's and 7's. When I told the guy at Cobra that, he thought those settings were quite a bit high, but I haven't heard Richard say anything about fouling plugs.
NorCal;Dynoed bike Thurs. have Cobra Swepts w/baffels, & Demon intake. Settings 3-2-2 62 H.P. Bike runs great with FI2000.
