I wanted to be able to mount my iPhone (GPS) and a cup holder for when I take long rides but I did not want the base mount to ruin the look of the bike when not in use. After much research this was the best I could do.
I purchased two RAM Mount Motorcycle Handlebar Clamp RAM-B-367U kits to install on the clutch and throttle brackets using the upper socket bolt on each. The kits comes with M8 bolts and the clutch and throttle brackets use M6 bolts. I used a grinder and removed the threads on the M8 bolts and then used a die to make M6 threads. All I had to do then was bolt it back together.
They do not stand out and if I paint them silver you wouldn't even know they are there.
