1 - 14 of 14 Posts
Hey Folks.
I have been jonesing for an Angel Eye type of setup for the Fury. I am confident I have found something that would work....
Sixty61 Custom Sportbike Parts & Spiked Accessories - spiked SportBike Bar Ends spike Frame Sliders, spiked windscreen bolts, spike fairing bolts, suzuki hayabusa parts, kawasaki ninja parts. honda cbr parts and yamaha parts.
Now...I do have a few questions......
Does a Xenon bulb replacement in your headlamp generate more heat?
Will this Halo Kit generate a lot of Heat?
Really wanting to get the White color to give it the full Angel Eye look.
Also would want to use the Halo while riding....(Not just for looks while parked)
Anyone have some advice?
Thanks,
DK
i think the Xenons do burn a little warmer than normal, but it's not too bad. and as far as the Halo staying on, it says it has an on/off switch so you could run it anytime, or just wire it into your headlamp...
I am not sure, I know from forum, GE nighthalk H-4 fits 40% brighter (white light)
Yea, I already have a SUPERbright silverlight h4 bulb that I installed, looking for the particular diameter of the outside of the headlight glass lens though, in order to fit one of these halo eyes or LED rings around... Can't go out and measure my headlight at this moment... Maybe Tony if he's sitting right next to the bike at this moment? ;)
I did the H-6 and know it is a little warmer if you hold your hand in front of it versus a stock but it hasn't caused any issues. I did change my housing to metal too though with a cobra unit
Aye, was thinking of that one too. Do you have pics of it?
Red, no exp with this, does it go behind glass or in front?:confused: going to dealer in 2hr, can ask?
Yea, go ahead and ask... Think it goes in front of the glass though from what I can tell.
:confused: There for if install inside glass, outside glass measurment not an issue, inside is, on glass or housing rim, also heat not problem since it is a cool ccf, but higher bulb for headlight might be with a plastic reflector, might have to go to metal. I think halo would mount inside?
lol, ask the dealer...!
ATT: Talked to manufacturer, he will bring in Fury tomorrow to measure up and tell me what size will work or he will make up correct size for Fury. Inside glass install with silicone. Also have access to new rear Fury SE rim, still in crate, never installed, black with red edge rim, one slight scratch 2/3 in long, pencil thin from bad handling, just slight paint damage.:D Will post in parts for sale.
1 - 14 of 14 Posts
