1 - 4 of 4 Posts
I added the kuryakyn deep dish bezels with smoked lenses today; amazing how such a simple change makes the bike look soooooo much better!! But after putting them on and heading out I notice at some point that the left front turn signal bulb is running very bright all the time; apparently the two circuit bulb is running both circuits all the time, until you hit the blinker then it goes dimmer. I'm assuming this is backward from what it should be doing. Also the housing was noticeably hotter to the touch than the right signal, which seems to be running normally. Any ideas what would cause this?
adjust the bulb....i had the same problem....if the bulb in not sitting in there just right it will do that....just take the lenses off and take the bulb out and put it back in there and dont push it so hard.
Discussion Starter · #4 ·
Thx guys; re-seating the bulb worked. although it took a lot of time and effort. Apparently on some turn signals the springy plate back there can be kinda fussy, according to my dealer. Took me half an hour of cautious working the bulb back and forth and around to free it up from the position it was stuck in, and then, for some reason, another 20 mins or so to get it to seat in the detente position where it made contact and worked properly. But it appears all is well, and those bezels look so great it was worth the extra effort. Now, on to the pipes, fwd cntrls, side plate holder, risers, ad infinitum lol :rolleyes:
1 - 4 of 4 Posts
