L&M's Does mount securly @ the lower original mount . Looks great to .
Sorry not a spike owner yet but i had a thought. Im trying to visualize whats going on. If it's just a matter of the backplate not staying secure to the rubber boot, could some type of adhesive help?the backplate of the aircleaner itself just moves around the rubber boot -
I have just under 1/4" clearance between the trailing edge of the backplate and the front of the rear spark plug cover; about 1/16" between the front of the throttle body cover and the back of the front cover - while the unit has not moved enough to contact either cover, it's so close, and the degree of movement possible could definitely make it happen. Granted they're plastic covers and fairly cheap to replace, but who wants to do that?Why do you feel this movement is a problem?
This is how the unit was designed by Honda. If they wanted it solid it would not have been rubber mounted. The throttle body is rubber mounted to the engine. The air cleaner is rubber mounted to the throttle body. All of this rubber allows the air cleaner & throttle body to move slightly.
From what I've heard, you do not need to add a fuel controller. These are the findings from S&S.I have a question as well, If you replace the intake and not the exhaust do you need to add a fuel management system?
ThanksFrom what I've heard, you do not need to add a fuel controller. These are the findings from S&S.
Gotta cast a STRONG vote for forwardJust finished intake , Dont no if better up are forward , what do yall think .
Will do. Gonna try a re-install first though with new boot and clamp; see if it is any tighter around a different boot. I'll pm you if I can't get it to where I want it.well if you decide to get rid of the s&s let me know I would be intrested if the price were right
Whatever the dealer thinksi will put on whatever the dealer thinks will produce the best ride possible....will have pics next week...can't wait
GO BRONCOS!!!!!!!!!!
