1 - 4 of 4 Posts
Ok today i changed the oem pipes on friends bike, when i took off the oem pipes there was a bracket near the rear wheel so i went unscrew 1 bolt and 1 nut.... Was i wrong --holly shit. When i looked from the other side i should have been 2 bolts..Hear is the problem the nut i took off was from the motor to the frame and i can't get it out to put the nut back on. It is the bolt with a metal spacer on exhaust side. see pic.. Im thinking if i loosen the other side nut maybe i can knock this one back out ?? Maybe the weight of the mother is stopping the bolt from moving back out..How the F--- do I pull the bolt back out so I can put the nut back on ????
You probably need a real mechanic like 460 to give you a tip that works but I would put a jack under the motor and just lift it up 1/2 to 1mm or so to allow you to get the bolt back in.
1 - 4 of 4 Posts
