Horn Relocation
5754 Views 32 Replies 21 Participants Last post by  StPeteAPB
Just installed Accutronix forwad contols, horn has to be relocated. If you have done this where did you relocate? THX
1 - 20 of 33 Posts
on the handle bars!
:) sorry had to do it....
Just reach up and squeeze..lol..:D.........sorry like he said jus too easy
The basket is in the way:D
Now thats funny...:D
I have the +3 inch forward controls. I used the main bolt that attaches the controls to the frame to secure the horn. The horn lines up perfectly and fires downward once installed. You can attach the horn to the left control so the horn is positioned correctly before lining up and threading the bolt through. You'll see what I mean once you try....
Man, Redspawn, you need to polish your bars.
here ya go...
Is that what happens riding year round in the sunny southern cal weather.:)
2
Put mine here: Sry not the best pics ...
Who needs a horn?
There are about 101+ places to relocate your horn, here is 1 of them. On Predators bike, I mounted the horn under the rear fender. In front of the tire, under the swing arm pivot, you will see a cylindrical charcoal canister. This canister is attached with two 6mm bolts. Loosen the big nut on the back of the horn so you can re-clock the mounting bracket. Bolt the horn to one of the canisters bolts, tighten the horn nut, lengthen the horn wires & route them to the horn following the stock harness. If everything is mounted correctly your horn will be as loud as factory & out of sight, & pointed so it will not fill up with water.
If you ever have a problem with one of my parts, e-mail me or call me & I’ll do what I can to help.
Photography Vehicle Tourist attraction
Thank you
Troy
623-516-9600
Thank you
Troy
623-516-9600
This is what i'm looking for, out of site thx. Bought controls on line got a good deal, Elite with slotted pegs look very nice...all I need now is my wheels from pathetic Chrome Pros.:mad:
makes two of us looooooooooking for those wheels.
While your at it, why not upgrade the horn (imo) to a Stebel? Very loud and small enough to fit like Accutronix Billet said. I put the Stebel there. Gets ppls attention.
Link: TwistedThrottle.com : Stebel Nautilus Compact Dual-Tone 12-Volt Motorcycle Air Horn, 139 dB, Black or Chrome - Stebel
I want an air horn like the truckers use:)
Fury10,
What did you order for the mounting bracket and wiring kit?
Fury10,
I'm kind of curious of where you mounted it also, that's an awful large horn.
1 - 20 of 33 Posts
