You don'tHow do you adjust the idle?
Anything is possible if you have the means. You will require Honda's software and harness interface to the ECM to connect with your computer. After considerable training you will be able to re map the controller chip to a different idle speed. This can be accomplished after sharing a considerable amount of beer with Honda's field service engineer and voiding your warranty. Harleys can have a lovely low loping idle with their roller bearing big ends and resulting lower oil pressure. Dropping the idle and oil pressure on a plain bearing Fury may not be a good long term investment. Just sayin' is all.just wondering if anyone has anymore info on slowing the idle down. if its even possible?
lol. well i that just answer my question. Thanks GarcAnything is possible if you have the means. You will require Honda's software and harness interface to the ECM to connect with your computer. After considerable training you will be able to re map the controller chip to a different idle speed. This can be accomplished after sharing a considerable amount of beer with Honda's field service engineer and voiding your warranty. Harleys can have a lovely low loping idle with their roller bearing big ends and resulting lower oil pressure. Dropping the idle and oil pressure on a plain bearing Fury may not be a good long term investment. Just sayin' is all.
