The outside diameter of the baffle is 2 1/16" and I would imagine the inside diameter of the pipe itself would be 2 1/8"
The outside diameter of the baffle is 2 1/16" and I would imagine the inside diameter of the pipe itself would be 2 1/8"Does anyone know the inside diameter of the Cobra swept exhaust by chance? I dont have a set of calipers here and pulling the baffles and measuring them would be a lot of work. From the best I can tell they LOOK to be 2 1/8" ID but would like to know for sure. I am thinking about ordering a set of Big City Thunder Baffles and trying them out, they are suppose to give a deeper sound but still not be as loud as no baffles at all.
Big John, I would be interested in knowing how you make out with them and how they sound. Give us an update as to how they sound once you get them in.Thank you very much Dave. I am going to order some and give them a shot.
Try heating them up to get them back into shape then slip them in. They might be a bitch getting back out but they can't be any worst than the stock ones. I have a hole in my garage window now where I threw one of those F&%king banana baffles threw it when I finally got it out. WTF did they really have to design it like that?Well they are all but done. I just have to head over to a friend's house to use a slide hammer and a metric tape for a new screw hole. I should have sound results after while.
All tack welded up, at a slight angle to help with install...
Inside shot, the smooth shoulder side will go in first...
EDIT: Slight problem, I think I might have ovaled them slightly when I had them in the vise. I am going to do a little adjusting on them tomorrow so they will fit. Results will follow.
After viewing them I'm not sure how you can get any decent sound with that configurations, maybe the two reducers in size makes a good a waffle effect and make a good sound. Curious to hear what they sound like.mr flathead would ticket me for those,but they look good.
GOOD JOB! i wish i had the know how to do that!Will do Dave. I am going to try a little $13 setup first that I saw while researching them.
Here is what a Monster Bffle looks like...
Here is what I am going to try...
We will see how they turn out shortly.![]()
Thanks for the details. If I get pulled over, I'm just gonna saw the original baffles in half, bore out the end baffle wall and insert it back in. I'm sure that would suffice to stop the "night stick test."Some states require baffles and some don't. These are not thunder baffles but a simular homemade version. I personally think the no baffles are just loud and don't really have a tone to them and these baffles quite them down a little and add a deep tone too the pipes. The slight increase in back pressure can improve performance over straight exhaust but it would be a very small amount. If you are happy with the sound of straight exhaust and your state doesn't require baffles then this would probably be a waste of time for you.
Yeah I saw that and coundnt really figure out what it was. It might be something to up the backpressure or it could just be a little bar to help with install and removal. IDK?GOOD JOB! i wish i had the know how to do that!
i was looking at the monster baffle and is it me or is there also something in the baffle? look at the right side and in the tube, there is something in it.
I am sure it also changes the sound and back pressure.
Thunder city claims that you will get better peformance and louder deeper sound then you would with the stock cobra baffle.
I would go with no baffle but you loose peformance that way. This seems to be the best way to go.
