I just bought the Kury Run/Turn/Brake controller, and am having some difficulty with install. After watching the video on cruisercustomizing.com I was able to locate the 'boot' that contains the wires for the right and left signals, and the brake light. The problem is that the connectors in the boot (located under the fender above the rear tail light) are much different than in the video; they each have a second wire running adjacent to them into the same connector, and there's a fourth wire connector on the controller (for the rear running light I assume) which would be left unfilled.
Have any of you installed this controller? I'm wondering if I'm looking in the wrong places, and I could sure use some words of wisdom.
