Here it is from an experienced rider !!! OK for the Look it is a little bit bigger yes ! but If You are not experienced do not do this upgrade! The 240/40/18 dunlop tire has a serious drop off . meaning the tire is egged or bubbled ... An experienced rider will use the same amount of tire on this upgrade as they would on the stock set up OEM . When I was concidering this upgrade instead of the SUMO-X I asked specifically if the tire would be egged or bubbled and I was told no well I was mislead . Kosman welding did a great job but as far as this upgrade i do not recommend it . You will achive a bigger look but there are other options i wish I explored and probably will in the future .Here is a pick of the 240 next to the stock 200 .
