How do the levers feel compared to stock?
and i thought i was the only person who thought this. I had to run one of the screws/bolts backwards from the inside out to correct the problem. I must have sat there for the better part of an hour trying to get that little screw started.Got my new zombie levers installed today,really easy and
really like the way they look.Also put on my new Kury engine covers,while they do make the engine look much better i would love to kick the designer or the person who welded the nut on the right side lower cover in the nuts.They welded it on crooked,what a pain in the a$$,but with my wifes even headed tempermant and patience it is all installed.Will get some pics tomorrow,now where did i put that beer?
Thats what i ended up having to do,think i might run down to the hardware store tomorrow and see if i can find some stainless bolts,or i might undo them and paint the heads black,thanks for the heads up on the rusting though.and i thought i was the only person who thought this. I had to run one of the screws/bolts backwards from the inside out to correct the problem. I must have sat there for the better part of an hour trying to get that little screw started.
Now get ready for the real fun. That tube that holds both sides onto the bike, yeah those little bolts rust like a MoFo after your first wash. Have fun chasing the rust trails from the stamped steel bolts.![]()
Is it all the bolts or just certain ones that will rust? Why not match up the threads at a hardware store and get some that wont rust.and i thought i was the only person who thought this. I had to run one of the screws/bolts backwards from the inside out to correct the problem. I must have sat there for the better part of an hour trying to get that little screw started.
Honestly, cause im too damn lazy. I want to ride like this ...Is it all the bolts or just certain ones that will rust? Why not match up the threads at a hardware store and get some that wont rust.![]()
I have 4 spots that show rust already on the bike. The bolt that holds the Cobra luggage rack on the back. The little bolts on either side of the Kury engine dress up kit. And the adjustment screw for the clutch at the top the left hand grip.Is it all the bolts or just certain ones that will rust? Why not match up the threads at a hardware store and get some that wont rust.![]()
I understand only wanting to do it once, that's why I was asking.Honestly, cause im too damn lazy. I want to ride like this ...rather then fight to get those damn little bolts back in. Its one of those things that i will do when im bored off my ass, and have nothing better to do with my time. I dont want to take away from the fun of owning the Fury just yet.
I installed mine yesterday and the same thing happened. I drilled it out and just put a new bolt and nut on it.Everyone has had problems with the lower bolt stripping due to the angle of the nut on the right lower piece.
Also that material that bolt is made of is very weak.
Mine broke off and I left it that way and used double sided sticky tap on the back to prevent rattling..
I thought I must have stuffed up.Your not the only one that had that problem, stripped mine out, pissed me off...
