I was riding last night and I noticed that my front running lights weren't on so I pulled into a parking lot and sure enough both front run/turn lights were not working. It is just both front light and both back lights still work fine so I figured it was a wire or a fuse or something. I took the headlight apart today and found the fuses on the bike to diagnose the problem, there is not a separate fuse for the front run/turn lights so I started looking at wires. All of the wires looked perfectly fine so the test light came out and I have power all the way to the little board inside the turn signal. Has anyone had problems with the silver bullets going out? I am going to call Kury Monday and see if I can get them replaced under warranty since they are less then a month old. I did look on Kury's website and they are about to release a super bright version of the lights that looks like they use the CREE small square LEDs so that will probably be a upgrade for mine when I get them working.
