would the levers listed fit the fury. Küryakyn[/QUOTE]
If you are talking about the wide blade chrome levers. yes they will have em on mine.
I have read some reviews stating issues with the wide blade clutch lever not engaging enough to start the bike in gear. I've also seen problems with too much up/down play in the levers as well. Are you experiencing any of these issues?If you are talking about the wide blade chrome levers. yes they will have em on mine.
I have the wide ones on my VTX and they are sloppy (loose ) up and down, but doesn't bother me much.I have read some reviews stating issues with the wide blade clutch lever not engaging enough to start the bike in gear. I've also seen problems with too much up/down play in the levers as well. Are you experiencing any of these issues?
Thanks for posting.
Yes they are sloppy loose up and down. whit a bump and you hear em. I but the wahshers that come with the kuryakyn pegs and it helped with that. Now as far as the clutch engaging, just tighten it up and your good.I have read some reviews stating issues with the wide blade clutch lever not engaging enough to start the bike in gear. I've also seen problems with too much up/down play in the levers as well. Are you experiencing any of these issues?
Thanks for posting.
