L and M Spring
4244 Views 27 Replies 10 Participants Last post by  Clueless
2
When L&M asked for someone to check out their new shock I volunteered, after talking to Chris, he offered to send me the spring and let me install it myself, as I have had my shock apart 2 or 3 times. Got it Tuesday,:D went back into work to put it on my shock, you need a press to install it, and went for a short 20 mile ride trying to get a feel for it. I was surprised at how little it affected the ride, it was a little harsher on the really bad bumps, (it is strange actually LOOKING for bumps in the road to hit) but over all, pretty much the same. Handles and rides really well, Looks good, dropped my rear fender right at 1.5", my side mount plate did hit the final 1 time on a really crappy RR track, but my plate holder does hang down quite a bit , shouldn't be any problem for most of you. I turned up my preload and haven't had any problem the rest of the day. Install took about 2 hrs total, have to remove the wheel/tire, and lift the tank at the rear to get the shock off. Here is a link to some pics I took L M Shock pictures by jcbrew - Photobucket
1 - 20 of 28 Posts
I noticed you have a spring compressor in your shop.
Do you think a home coil spring compressor would get the job done?
Would it be best to take to the Honda dealer to have it done?
T
Awesome!, when can we buy?
Dont know, should be soon according to Chris, he is waiting to hear from another "beta tester"
T
That wouldn't work, there is a shock down the center, you need to compress the spring to release a keeper ring that is under the preload adjuster, so it need to move about 1 - 1.5 inches, release the keeper and it comes right apart. When I talked to him this morning, Chris said you pretty much need a press, or take it to someone with a press, but they were working on a tool to provide that would be a little easier (and safer I would think) than the steel blocks I use. But I have been doing this to GL shocks for a couple years. There are shock tools on the market that would work, but probably be cheaper to pay some one than buy a tool for 1 time.
TKS Clueless, looks great! If you have time do you think you could post a full side on picture of bike, on stand and upright with you on it? Thanks again for your very informative posts! THREE THUMBS UP!:D Ride Safe.:)
I will try to tomorrow
Very good, Looks sweet with the drop. Thanks for the intel.
Dont know, should be soon according to Chris, he is waiting to hear from another "beta tester."
Maybe me? Unless there's another spring out there... I will have a full review for you guy's here soon, I too got mine back today and got it reinstalled into the bike. I'll get back with you guy's here shortly on my initial review.
...hey red u have to pull wheel to get shock off ??
No, have a pic of that too here soon, some reason my phone card or email from my phone isn't cooperating with me...
We are working on a PDF manual for this Honda Fury lowered rear shock install. It's a little tight, but you can remove the shock without removing the rear tire, you just have to raise the bike off the ground to let the swingarm drop.
Once both Clueless and RedSpawn give the thumbs up, we will do a pre-release special for a couple of days. We have everything in stock and soon we hope to have a Honda Fury lowered rear shock video over view.
LM
...Sign me up...:D..can't wait.......
Calling dibs on 1 out of the first batch....I need these ASAP since my bike is apart at the moment.
Hey now ...I live closer to az than you dont that count ??
Nope, Hydroboy called dibs first, it's only fair!:)
I would like to know the spring rates because this looks like the stock spring with a coil cut off!
http://i300.photobucket.com/albums/nn13/Tungstang/photo-17.jpg
Don't worry man, there should be more than 1 in the first batch.
since you pointed that out im kinda wondering,
It isn't the stock one, it is a little softer actually, and Chris indicated that they have more than 1 spring for for different weights of riders.
1 - 20 of 28 Posts
