1 - 11 of 11 Posts
These companies are charging anywhere up to $260 for a strip of LED lights with some wires and other things to attach them!!! What a rip off....
You can get a strip of LED lights from ebay for under $10....All it takes is someone to figure a DIY and we can save a lot of money on changing Honda's disgusting stock lights.....
Lot of good DIY guides on here for all sorts of things... Make sure you do a search for them... We are trying to get a DIY section made in the Forum area, hopefully that works our right Richard???
Here's one...
http://www.furyforums.com/forum/fur...n-signal-mod-led-light-install-beginners.html
That is actually an awesome link...my only questions is do we have to buy the LEDs from Radiantz and these other companies, or are these the same LEDs you can find anywhere else for super cheap...
A DIY section would be awesome, especially if it had ranking for difficulties of the mods....:)
On the guide, I wrote that you can buy those LED's, or just buy some different one's (cheaper one's even) and mod that guide to your needs bro :D Just follow the basics of that post and you should be fine.
You may want to be consider the LED brilliance factor. This is your RUN/BRAKE/TURN indicator. Too low a brilliance factor and they may not be seen during daylight hours.
I myself value having my RUN/BRAKE/TURN indicators being seen an willing to spend the money for quality LED product.
If I'm correct, I believe the RAW product uses Radiantz product in theirs. (Not certain)
TopsFury has another link for LED's
Here are some LEDs, they offer a good product, also when I was installing the LEDs and had issues, I phoned them, they were very helpful.
LED Flexible Arrays - Amber - Chrome Glow
Ask for Chris
yes Raw uses Radiantz, Radiantz is one of the few that i have seen you can designate size relatively easily and have the LED's chained together for an easy attachment so its just like wiring up a basic lighting assembly if you do rss's front signals and a home made raw with the run/stop turn module your overall cost will be about 200
Rear only - 94$ for the lights, 60$ bucks for the run/stop/turn module... then if you have the metal laying around, that is your total cost... Just got an e-mail from fed-ex, my module is on it's way... so this weekend or next I should be putting it all together...
Front setup only cost me about 100$ or less... it's in my guide tho...
1 - 11 of 11 Posts
